HotSpot with 2 radius servers?
Can i configure my HotSpot to use two radius servers?
I want to keep user manager (for PayPal payments)as one radius server, and would like to have another radius server for credit card payments.
I have a rb433 with Hotspot and UserManager running on it.
How do i add another radius server on the same hotspot?
Please help with solutions
Thank you
No, it is not possible to have 2 RADIUS for the HotSpot on the same router.
Sure you can.
http://forum.mikrotik.com/t/hotspot-with-more-than-one-radius-userman/36710/1
SurferTim,
I think you can’t use usermanager and another Radius at the same time. : /
Yes you can. You can’t have two copies of UserManager on the same router. On different routers, no problem.
Very interesting then. I think I could use this on one costumer.
Thanks!
Yes, it is possible with additional configuration.
It is possible with domain (all users should be on the specific format).
As well you can split HotSpot/UserManager by virtualization.
Thanks for your answers.
I will try to configure it.
But just to make sure:
I would like to use:
  1. 1st radius server -User manager which is running locally on the rb433 and i would configure it for pay pal payments, and for prepaid vouchers.
2)2nd radius server- is a remote server which would deal with credit card payments
So this scenario is possible?
Because somebody mentioned that it is only possible if both Radius servers are remote servers.
Thank you
Yes, this scenario is possible, just do not forget about the domain settings for the username format.
