i am setting up a hotspot/captive portal with >1000 users on a CHR running 7.3.1 and a trial P10 License. With few users inside, everything works as expected, but when I let the mass join the hotspot VLAN, I get an error instead of the captive portal page:
ERROR: Not found
While trying to retrieve the URL http://bla.com
Resource temporarily unavailable
[…] Generated […] by MikrotikHttpProxy
I already increased the max. concurrent querys in the DNS config, and the max client/server connections in the web proxy settings.
CPU/RAM Resources on the Hypervisor and the CHR are OK and available
I am surely hitting a limit in the Proxy configuration that generates the captive portal, but I can’t find any settings for that.
Hi Nico, I saw that you commented in my post, and we have a similar problem hehe.
So I am trying a lot of configs without success, the max concurrent clients on hotspot with trial mode that I achieve was is about 1600, but the captive portal response become very slow for about 1000 users. I am installing a CHR and see it was hardware limitations, if I get some results I will post here too.
Only one doubt, how did you do that? —>. “I am surely hitting a limit in the Proxy configuration that generates the captive portal…”
Hi @camilobom, I have a Support Ticket with Mikrotik regarding this issue and already tested two patches without success. I got confirmed that the developers are still working on a solution.
The Error I get from the Captive Portal webserver is: “Resource Temporarily Unavailable” so I assume that I am filling the reserved RAM either for the Webserver or for Iptables, and that is the Resource that becomes unavailable. But it is just guessing, there is nothing on the logs of the device. My CHR is dying much earlier, with <600 dhcp leases. If I have news to share, I’ll also post here.
I install a CHR on a dedicated server with an intel Xeon Processor and 32 GB RAM. The users now is around 3000!! and keep raising. The captive portal is not slow anymore!
The only explanation that I could imagine, its the CCR has some limitations for specific services like hotspot, where they reserve a hardware limit. I hope mikrotik fix this limitation for their boxes.
I appreciate your help! Thanks.
Ah, sorry for the misunderstanding, mikrotik made a patch and routeros no longer shows this crash. Running 7.19.2 atm with ~10k hotspot users in peaktime.
