Hotspot with public nat to nat translation working example
Dear Board,
it’s my first time I try to use public IP address for my hotspot users with nat to nat translation. But I didn’t could get it work even with 5.26 or 6.18. Maybe I’m blind but I haven’t found any instruction for nat to nat in hotspot environments. A hint would be great.
My problem:
After putting in my credentials into the authentication page, the redirect isn’t working. In /ip hotspot active I see my session with the correct public IP, but thats all.
To clearify: This config snippet is from a RB 751 with default config, e.g. 192.168.88.1 on bridge-local. I also put in my public IP space, to point out every detail.
/ip hotspot profile
add dns-name=access.mlua.de hotspot-address=192.168.88.1 html-directory=
hotspot http-cookie-lifetime=1d http-proxy=0.0.0.0:0 login-by=
cookie,http-chap name=hsprof1 rate-limit=“” smtp-server=0.0.0.0
split-user-domain=no use-radius=no
/ip hotspot
add disabled=no idle-timeout=5m interface=bridge-local keepalive-timeout=none
name=hotspot1 profile=hsprof1
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add name=dhcp-nat ranges=213.178.191.172,213.178.191.173
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=
static disabled=no interface=bridge-local lease-time=1d name=dhcp1
/ip hotspot user profile
set [ find default=yes ] address-pool=dhcp-nat idle-timeout=none
keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m
transparent-proxy=no
add bridge=bridge-local disabled=no edge=auto external-fdb=auto horizon=none
interface=ether2-master-local path-cost=10 point-to-point=auto priority=
0x80
add address=192.168.88.1/24 comment=“default configuration” disabled=no
interface=bridge-local network=192.168.88.0
add address=213.178.191.171/28 disabled=no interface=ether1-gateway network=
213.178.191.160
add address=192.168.88.0/24 dhcp-option=“” dns-server=192.168.88.1 gateway=
192.168.88.1 netmask=32 ntp-server=“” wins-server=“”
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
disabled=yes src-address=192.168.88.0/24
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=4096 servers=213.178.191.166
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=213.178.191.161
scope=30 target-scope=10What is wrong? Where is my mistake? Attached you will find the hole config.
Thanks!
hole.txt (18.9 KB)
