hi,
i am trying to use SSL request for Hotspot user for logging
i import certi & it displaying too in certificate menu
but i am not able to find IP–> services–>> hotspot-ssl
how to enable that , i am using 5.18
hi,
I think you just set the login-by to https.
/ip hotspot profile
set X login-by=https
If you use an external radius server, beware the password is not encrypted. The connection from the hotspot router to the radius server must also be secure.
http://wiki.mikrotik.com/wiki/Manual:Hotspot_Introduction
