Hotspot without authentication
Is it possible to set up hotspot without clients having to authenticate ?
We only want to use the advertising feature on them but we dont want them to perform any login or authentication.
Is this possible ?
Maybe Hotspot profile → “Trial” will do the job.
I haven’t tried
The Trial wil work…
You can design the hotspot page with youe advertising / splash page and place a “go” button on it . this will pass the trial param back to the HS controller and they are off.
You can use advertising etc with the same settings under profiles..
Craig
