Hello
I created this user name: user1 limit-uptime: 1h password: pass
And it works, but how i can control, if the user is disconnected do not run the limit-uptime, until the user come back?
Hello
Why do you want to setup a hotspot without userman?
I think what is happening is that the time starts when the user first log on and then continues until 0
because i want to use PHP API, but i do not know how i need to configure the user to stop the “limit-uptime” when they are disconnected
I have a little question regarding same issue.
I want to make a hotspot user (shared) with 1hour access time limit after first login.
It is needed for a school, for connect a class of students to use internet for 1 class hour.
It can be made without userman? Because normaly hotspot count uptime, and maybe it will be remaing uptime, and tomorrow the sudents will use same password.
That user/pass to be for 1 hour not 1 uptime hour from first login.
i hope it is possible, and i don’t setup correctly
thanks
ronn
