Hotspot Won't Load login.html
I’ve got a hotspot set up that is having an odd issue. Normally you’d connect via WiFi and then type a website (such as www.google.com) and it would automatically redirect to the login.html page (this is on PC and not phone). I’ve updated the login.html page as per my customer’s specifications and now the login page won’t load. When I go to 10.x.x.1 (IP of the MikroTik from client side) then the login page loads as it should. When on a phone it pops up saying “log in to hotspot” (or something to that effect) which redirects to the page as it should so on mobile it works fine.
I’ve tried to find this in the past as my test hotspot is behaving exactly the same way (and always has). Does anybody know why?
Cheers!
