Hotspot
How i can configure my Hotspot to every user can just connect durin 8:00 in morning until 16:00 Afternoon
i configured WIFI with CAPsMAN
I have CAPsMAN user and hotspot on it
My plan first is every user those connect to User WIFI have duration 8:00 to 16:00 every day
Other Free AP wifi (CAPsMAN) are for turists : And plan is those Turist will have first 20s full band then after 20s have max limit 1Mb then after 20min speed down to 512kb
thaks
You can use the scheduler (under /system). You can run several commands at 8:00 like “/interface enable 3”… And at 16:00 the command will be “/interface disable 3”
thanks but i dont want use schelduler , i want to configure by Queue if it possible ?
