Hotspot
Hello ,
Which one is the best device for creating a hot spot to handle 100+ clients at a time?
What is the range in terms of distance ?
Thank you.
You would most likely need more than one ap to handle that many users simaltaniously. Wi fi is not perfectly suited to doing that but can work quite well if setup correctly but does require quite a lot of knowledge to do it right.
