Hello every one
I want to install hotspot on my mikrotik
I have ver 2.9.6 and used wireless through AP
please Guide me what to do
I was search on Manual I can’t find what benifit me
thanks
I’ts very easy to setup with the latest version. Just go to to winbox menu ip, then hotspot, and click on servers, then hit the setup button.
-Michael
ok
I was enter to the setup but I can’t understand some items if you can guide me
how can I insert html page on it and where I can put it
othere hand how much size I can put it
other question can I use it e.g in on port like eth3 with no internet
and make eth2 for internet
please help me to do it I need it too much
You have maybe the easy way via CLI
In first step, go to the ip hostpot>setup (enter)
You have choice of interface, which one would be hotspot, not the one with Internet Access Route.
Second step is the give hotspot interface IP address, example 10.10.10.254/24
DHCP scoope, for example 10.10.10.50-10.10.10.253, the scope from 10.10.10.1-10.10.10.49 you can leave for any application for static IP.
DNS address
And You don’t need anything else, as soon as you have gateway and IP address in second interface of PUBLIC interface, YOU ARE IN THE AIR.
It is very easy
how can i activate the winbox in 2.8.28 from the main console
when i try to connect trhought a pc on the lan it´s return me an error type time out
any solutions
