Hotspot
good day. i have been struggling with getting userman to work with hotspot. i tired myself and then followed an online tutorial. unfortunately both are coming up with the same error. that being login failed: RADIUS server is not responding.
the hotspot and userman are the same router so i used 127.0.0.1 to get them to talk. I think it will be some small setting as i have had this result from 2 totally different sources.
anyone help pls! :slight_smile:
you have a proplem with your radius server .be sure of
ip radius put in your browser
may need reset your um database
