How can I create a dynamic user hotspot, besides web
$(link-login-only)? dst = $ (link-orig-esc) & amp; username = T - $ (mac-esc)
I am willing to use all the options for ssh, api, snmp, except web
What do you mean by “create dynamic user”? I don’t think even the router’s web page can create a user out of nothing, so it seems you mean something else… Do you mean like logging an existing user in? That can only happen from the user’s device, after it sends a request to the router with the credentials.
Can you describe your full scenario in more detail?
The trial included mikrotik if you can create a dynamic user. if the user will go to the link
$(link-login-only)?dst=$(link-orig-esc)&username=T-$(mac-esc)
I want to include a trial mode, but does not allow the authorization of the link.
This is done so that the user does not do automatic registration, and saw the login page.
