HotSpot
I have a zte zxhn h367n router and i want to use it with mikrotik routerborad. I have configured a hot spot and allowed an url.
When i connect to the hot spot the site does not load.
When i use an old dsl modem all works fine.
Is there a possibility that the zte conflicts with the mikrotik?
Thak you for your help!!
I think your problem is dhcp or a wan port on the zte.
Try to set the router up in bridged mode.
If it plugs into one of the hotspot ports on the mikrotik, it should work
Disable the hotspot and see if it works.
If it doesn’t work, then your basic router configuration is flawed.
Check the NAT and firewall filter rules
See if the Mikrotik itself can ping something on the internet (8.8.8.8, 4.2.2.2, etc)
Make sure your hosts are getting valid DNS server address(es).
