Hotspot
it is the following one,
I configured hotspot and is functioning. But pro Mikrotik to work, is lacking some details:
1° - How I make to hinder that the customers have access other computers of the Net?
2° - Through the Hotspot, it has as to hinder that using if they connect in the net without registered in cadastre MAC? If… it does not exist alternative?
3° - How I make to configure 03 Plans of different Speeds in the Hotspot if the Mikrotik alone mounts 01 server for each wlan?
I wait Aid…
I’m not sure that I understand your questions correctly.
  1. Do you want to block access between HotSpot users ? Do you have wireless or wired (Ethernet) customers ?
  2. Do you want to block access to unknown MAC-address users, or want to apply specific actions ?
  3. Use ‘rate-limit’ to apply simple limitation per user’s entire traffic.
    http://www.mikrotik.com/docs/ros/2.9/guide/aaa_hotspot
