HotSpots and Banner Ads
I am trying to build a Hotspot where after the user logs in a 1.5 inch high banner is forced at the top of every web site visited after the login. Any thought on this
Mark Spencer
Any luck with this?
Do you really want to display this banner on the top of EVERY page?
There’s an advertisement function in the 2.9 hotspot, which allows you to open ads every so-and-so minutes.
To achieve what you want (if I understood you correctly) you would have to use something like a transparent web proxy that modifies every page requested through it (inserting the banner at the top). Not THAT easy…
Hint: Search Google for squid and icap - that would be a way…
Best regards,
Christian Meis
Good points, however, in the 2.9 manual, it mentions that you can do these ad items, however, it never says “HOW” to display ads every so often.
Can you give me a direction on that?
Yeah - using WinBox:
IP → HotSpot → Users → Profiles → “Advertise” tab…
in console that’s somewhere like “/ip hotspot user profile”, then set the advertise parameter to yes and you can configure the rest (URLs, timing, …)
But this is in the manual, although a bit hidden if you ask me:
http://www.mikrotik.com/docs/ros/2.9/guide/aaa_hotspot, see section “User Profiles”…
Best regards,
Christian Meis
