hotspotting help
Howzit
I need a little help with something.
I have had a request to setup a HS for a client. I’m planning on using radiusmanager to handle the netcash transactions for the credit card.
The part i need help with is he want to be able to offer Some Free data and then after that has be exceeded have them purchase Data if they need more.
This is where my knowledge breaks down. i have no idea how to accomplish this, Is there anyone who can help me with this
With Mikrotik Hotspot u can create some guest users and limit data.
That is true but the problem is the owner then needs a list of users to give out those that want, what i need is something that will allow access to a point then throw up the HS page request payment for further use
Have you considered using the built in Trial feature ?
http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot/Profile
that sounds like what i’m looking for
right, it doesn’t seem to be working.
I believe the trial is suppose to give me access to the internet for the amount of time that i have stipulated and then when that time has expired throw up the HS page, However this does not seem to be working. every time i try the HS page gets thrown up instead of giving me the 30mins that i set the Trial for.
is there anyone who can help me with this
Why is the trial system not working
Have you enable Trial from server profile…
Just double checked it, yes i was playing with the Trial system within the server profile
