Hotstop bridge vlan filter (private ip behind router)
When I first started using hotspot with mikrotik, i had a problem figuring out why i was seing private ip behind member routeur. I found a solution by putting my interface in a bridge and adding bridge filter in intput to the public ip i’m giving to member.
Now, i’m trying to add some vlan into this bridge to separate some section of my network, but filter don’t work, i see the private ip of member. I tryed to add bridge vlan filtering in such way, but filtering don’t work in input.
Is there a way I can get it to work?
