hi to all!
i wish i could realize a point to point connection between 2 station about 15km of distance using:
2 rb532 with athers r52 (hyperlan mode)
2 solid dish antenna 29db 5ghz tecnology
nstreme enable
operating mode: Station WDS —> Bridge
perfect LoS and fresnel zone
it will be good?
what’s my maximum distance using theese above?
thx
This should work for you with no problems at all. You should be able to pull more than 40km, depending on many different factors of course. Such as Noise floor, channel, band, fade margin, and so on.
Matt
cool…d
what kind of power signal (wireless registration) shoulda find?
however,
channel is adjustable, while band is 20Mhz… other i don’t know now, only when i set
At 15km you should expect ~ -56 RSSI.
Matt
can any one write a brief setup for one of these stations to make a bridge ..??
