Now that 2.9 is no longer beta, is it perhaps a good idea to rename this forum to ‘version 2.9’ or something?
It makes it easier for posters to figure out where to deposit questions about a certain version…
this is not a 2.9 forum, but rather a beta/rc forum. or do you think 2.9 is the last beta version MT will ever make?
So all postings here since the release of 2.9 refer to 2.10beta?
they should. normis once told somebody that they are writing to the wrong forum section if they are asking about 2.9 full release.
In that case: When can we expect the first 2.10beta?
I would hope it would be a 2.9.x beta, or 3.0, but not 2.10 - thats not the right way to number things I think.
2.8 is legacy now I guess … so there should either be a forum for 2.8 or the beta one renamed and a new one created - anyhow, there is not a separation anywhere right now for 2.8 and 2.9 versions in the forums.
Sam
hope we con use this forum to write about some new functionality.
For exemple the WMM and channel size, through a wireless-beta package.
Or about routing-beta question
