Hi
I just received a RBGrooveA-52HPn but I have few questions with it:
where do I setup the antenna Wifi signal power ? what is best value to use for indoor (large area) ? I have setup it as france as I’m in france but not sure it makes a difference…
Thanks,
Vincèn
i also want this answer for metal 2shpn…but noone reply to my post
http://forum.mikrotik.com/t/best-setting-rbmetal-2shpn/91727/1
Go to: Wireless > wlan_interface > Select Advanced Mode > Tx Power
and set: “All Fixed Rate” and set the TX power you need.
