How assign Cloud Hosters Public IPs to vServers?
Hi!
can someone explain, how cloud Hosters assign Public-IPs from their Registry Adress Space to vServers?
To be more precise, did they use a default gateway with failover/cluster like vrrp?
And how did they prevent duplicate IPs from misconfigured vServers, if Customer-A Assign “accidentally” the IP of Customer-B?
Best Regards,
YAN
Hi!
for example, a OVH Cloud VM with public IP - how did they assign the Adress to the VM and how did the prevent users to change the IP?
it would be great if someone had some information about this :slight_smile:
Best Regards,
YAN
