How Backup my settings?
Hi all!
I using the user manager 2.9.39 version.
I configure the user,routers for pppoe authen.
How to backup mi settings?
I not find suggest the wiki!
Thanky you.
backup feature for User Manager will be introduced in the next version of the RouterOS
Only for mt3? :cry:
maybe we will also backport it to v2.9
/tool use export file=backup
that export only saves a part of your config
Thx Normis,all! :smiley:
