Hi, our office space is flooded with 2.4 Ghz and so want to switch to 5.8 to avoid issues / improve performance.
I’ve an RB411AR (v6.30), + 1x R52Hn (wlan1) with onboard radio (wlan2) disabled.
Have setup a basic AP with wlan1 and ether1 Bridged (bridge1), DHCP client on ether1 and DHCP server on bridge1. ether1 is connecting to an ADSL modem from where its receiving a WAN IP.
Wireless Mode is ap bridge, Band: 5GHz-A/N, Channel Width 20/40MHz Ce, Frequency: auto, Protocol: 802.11
Firewall NAT rule setup as: Chain: srcnat, Out Interface: bridge1, Action: masquerade.
A pigtail is connected to J4 (chain 0) with a 5DBi Omni antenna and chain 1 is disabled
With the above setup I’m able to connect from my laptop’s dual band radio, to the AP and connect to the internet.
My question are:
How can I improve the above setup?
To achieve a Max Rate of 300 (and general best performance possible), do I need to connect an additional pigtail and omni antenna to J5 and enable chain 1?
If so what kinds of antennas / how should I position them to avoid issues?
We have ± 20 wireless devices, most with only single band (2.4) wireless radios that I’ll replace with Edimax Compact Wireless AC600 USB Adapters. 7 desktop PC’s connect direct to the modem via LAN cable. We use VoiP as only source of voice communication.
