Hi every one I need to block Hotspot Shield program from mikrotik
I found this page on wiki
http://wiki.mikrotik.com/wiki/How_to_Detect_and_Block_Hotspot_Shield_program_traffic(openvpn_application)
But I have Mikrotik 4.16 so when I try it it did not work as they say that in page “it work for mikrotik 3,3”
Is there another script for mikrotik 4.16
Thanks in advance
How to Detect and Block Hotspot Shield program traffic(openvpn application)
Some companies and organizations has its own security policy , sometimes they use OPENDNS addresses in order to prevent users in these companies and organization from accessing certain web sites .But there are many PROXY and VPN client programs that can help you bypass these policies and one of the most famous and fastest VPN client program is Hotspot-Shield , it is free program and easy to install and use so keep in your mind that this kind of prgrams doesn’t use specific TCP ,UDP ports to establish VPN connection with different VPN server around the world so it do port hopping and it is use a well known port number to communicate with VPN server which is 443 as its destination port address , i have tried to block with TCP or UDP port addresses also when i block 443 it can not establish connection with VPN server. i have tried to block it using OPENDNS but no way after searching in many web sites i found that i can block this program if i have a digital signature for it but i don’t have . also i found we can match on connection with tcp port 80 content 127.0.0.1:895 in order to see the traffic that program send it .although that we can match the traffic but we can not block it
if you want to block this traffic in mikrotik v3.30 you have to add these rules into mangle and firewall
mangle rules
ip firewall mangle
add action=add-dst-to-address-list address-list=WhiteList
address-list-timeout=4w2d chain=prerouting comment=WhiteList content=
!127.0.0.1:895 disabled=no dst-port=80 protocol=tcp
add action=add-src-to-address-list address-list=HotSpotShieldUsers
address-list-timeout=1h chain=prerouting comment=HotSpotShieldUsers
content=127.0.0.1:895 disabled=no dst-port=80 protocol=tcp
!127.0.0.1:895 disabled=no dst-port=443 protocol=tcp
firewall rules
ip firewall filter
add action=log chain=forward comment=“Allow WhiteLists” disabled=no
dst-address-list=WhiteList log-prefix=WhiteLists
add action=accept chain=forward comment=“” disabled=no dst-address-list=
WhiteList
add action=log chain=forward comment=“"Block HotSpot Shield"” disabled=no
log-prefix=HotSpotShield src-address-list=HotSpotShieldUsers
add action=drop chain=forward comment=“"Block HotSpot Shield"” disabled=no
Note: if you use only these rules in firewall filter and mangle you will block all traffic from users that are using hotspot shield but if you want to block only traffic that belongs to hotspot shield and allowing users that are using this program to access the internet but not through hotspot shield program ,in order to do this you have to use these extra rules in DNS and DHCP i am using opendns , also you can use any other dns server addresses
use opendns server addresses
ip dns
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 primary-dns=208.67.222.222 secondary-dns=
208.67.220.220
you have to Make your Mikrotik router(DNS Relay) as DNS server for your Customers in DHCP
ip dhcp-server
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=
static disabled=no interface=LAN lease-time=3d name=dhcp1
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.117.0/24 comment=“” dns-server=192.168.117.200 gateway=
192.168.117.200
DNS server for users in my network is 192.168.117.200
