hi.
RB711 - Supports 1x1 MIMO
How can 1x1 be a MIMO??
-sid
hi.
-sid
well preciselly it should be RB711 - Supports 1x1 SISO, ref. http://en.wikipedia.org/wiki/MIMO. But can you imagine number of questions in this forum about this “new” technology?
even i thought i had to be SISO but then why Mikrotik has been advertising it as 1x1 MIMO?
Can we have some explanation on the 1x1 MIMO concept?
-sid
its 2x2 MIMO with chain 1 off on both sides …, what is unclear in this?
2x2 MIMO with 2 chains can be understood as it has 2 connectors for a Antenna made specially for that purpose. horizontal and vertical transmissions at the same time…
what is 1x1 MIMO for?? it has one 1 connector and works just like a standard radio.
depends on what you call a “regular radio”. it does work in compliance with 802.11n, so it’s not just a “regular radio”
there is nothing called 1x1 MIMO
LOL
They aren’t the only ones out there that say it.
Take a look at the Modulation and Coding Scheme for 802.11n.
You can have 1Tx/1Rx and it’s still 802.11n.
Even with only 1 antenna/1 stream, you are able to push a theoretical maximum speed of 150Mb/s, while on 802.11a with turbo you can only go to 108Mb/s.
I think that the confusion is between 802.11n and MiMo.
Kindly regards,
