How can drop netcut
Hello
How can drop netcut program
Please anyone know how to block netcut.
Regards
No answer
You cannot simply ‘drop’ it.
Bussiness class ethernet switches support a feature called Dynamic ARP Inspection,
but it only works with dynamically assigned IP addresses (DHCP).
Mikrotik doesn’t offer DAI.
But if a direct communication between the clients isn’t necessary and
all adresses are assigned via DHCP
you can use these Mikrotik features to get rid of NetCut etc.:
  1. use Port Isolation (this is called horizon bridging in RouterOS)
    → This avoids uses see broadcast-Frames and eventually MAC-Addreses from other uses
  2. use “arp reply only” on your Default-Gateway IP-Interface
    along with “Add ARP FOR Leases” on your Default Gateway’s DHCP Server.
    → This avoids the default gateway to learn fraud ARPs
thank you
and also u need forwarding option to disable in wireless interface
