how can i add tp-link 501 to mikrotik
/ interface wireless
set wireless name="wireless" mtu=1500 mac-address=00:1D:0F:F9:5C:B9 \
    arp=enabled disable-running-check=no radio-name="001D0FF95CB9" \
    mode=ap-bridge ssid="IT-System 0125357737 - 0101361712" area="" \
    frequency-mode=manual-txpower country=egypt antenna-gain=0 frequency=2472 \
    band=2.4ghz-b scan-list=default rate-set=default \
    supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 \
    ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default \
    periodic-calibration=default periodic-calibration-interval=60 \
    burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled \
    wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 \
    wds-ignore-ssid=no update-stats-interval=disabled \
    default-authentication=yes default-forwarding=no default-ap-tx-limit=0 \
    default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no \
    security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms \
    hw-retries=15 preamble-mode=both compression=no allow-sharedkey=no \
    comment="" disabled=no
/ interface wireless nstreme
set wireless enable-nstreme=no enable-polling=yes framer-policy=none \
    framer-limit=3200
/ interface wireless manual-tx-power-table
set wireless manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9\
    Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name="default" mode=none authentication-types="" \
    unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" \
    wpa2-pre-shared-key="" eap-methods=passthrough tls-mode=no-certificates \
    tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none \
    static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none \
    static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none \
    static-sta-private-key="" radius-mac-authentication=no group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no \
    audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no \
    frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no \
    memory-limit=10 file-name="" file-limit=10 streaming-enabled=no \
    streaming-server=0.0.0.0 streaming-max-rate=0
this is my config ineed help to add acces tp-link 501 to mikrotik server i add server in 501 in universal mode what can i do in mikrotik server to add 501 in it
