how can i allocate DATA MB to individual users on hotspot
First, you need to make the IP address of the client static, and then use IP Firewall filter. In the Advanced bar, use the connection byte tab to do that…
You can achieve that on the user manage page if you are setting profile on the ticket to print. You can set Limitations. You can read more there.
