How can i block p2p ???????????????
plz anyone can write to me block p2p
ever seen the manual? simply add a firewall rule with the setting p2p=all-p2p and then the action drop
http://www.mikrotik.com/docs/ros/2.9/ip/filter
Plz normis writre to me the code
no, i already told you what should be done, and gave a link to the examples. is it so hard to click on a link?
simply add a firewall rule with the setting p2p=all-p2p and then the action `drop
in the example
/ip firewall filter add chain=? dst-port=? protocol=? action=drop
i need somthing like this to block p2p
u can help me???
/ip firewall filter add chain=forward p2p=all-p2p action=drop
not easy?
Thank u alote
its easy for u but diff. for me man .
last question do u know anything about Cache ., can i do it in Mikrotik
do u have id chat i want talk with u if u can
this is my id
woody_love82@yahoo.com
if you are talking about caching,
web-proxy provides caching, but you MUST read documentation about web-proxy:
http://www.mikrotik.com/docs/ros/2.9/ip/webproxy
