Hello
i use my routeros as vpn server but the problem is there’s too many login attempts, how can i block them ?
# may/ 6/2022 13:48:13 by RouterOS 7.1.5
# software id = TI09-7WK3
09:55:20 system,error,critical router was rebooted without proper shutdown
09:55:27 interface,info wireguard link up
09:55:28 route,ospf,info OspfInstance { version: 2 0 rid: <CENSORED> } created
09:55:42 system,critical,info ntp change time May/06/2022 09:55:56 => May/06/2022 09:55:42
10:01:55 pptp,info TCP connection established from 78.128.113.70
10:01:55 pptp,ppp,error <0>: user 3 authentication failed
10:04:21 pptp,info TCP connection established from 78.128.113.68
10:04:21 pptp,ppp,error <1>: user test authentication failed
11:17:59 pptp,info TCP connection established from 91.191.209.236
11:17:59 pptp,ppp,error <2>: user ip authentication failed
11:21:09 pptp,info TCP connection established from 78.128.113.67
11:21:09 pptp,ppp,error <3>: user ww authentication failed
11:45:53 pptp,info TCP connection established from 91.191.209.235
11:45:53 pptp,ppp,error <4>: user test authentication failed
11:46:16 pptp,info TCP connection established from 91.191.209.234
11:46:16 pptp,ppp,error <5>: user 777 authentication failed
12:01:08 pptp,info TCP connection established from 91.191.209.236
12:01:08 pptp,ppp,error <6>: user az authentication failed
12:10:32 pptp,info TCP connection established from 91.191.209.234
12:10:32 pptp,ppp,error <7>: user 4 authentication failed
12:52:01 ipsec,info respond new phase 1 (Identity Protection): 217.182.xxx.10[500]<=>192.241.222.107[45049]
12:53:23 ipsec,error phase1 negotiation failed due to time up 217.182.xxx.10[500]<=>192.241.222.107[45049] 111555f681d524ef:f6d090bf71840787
12:54:14 system,error,critical login failure for user M via local
13:07:20 pptp,info TCP connection established from 91.191.209.236
13:07:23 pptp,ppp,error <11>: user yy authentication failed
13:10:52 pptp,info TCP connection established from 78.128.113.70
13:10:53 pptp,ppp,error <12>: user cc authentication failed
its my firewall rules:
add action=accept chain=input comment=Winbpx dst-port=6945 protocol=tcp
add action=accept chain=input comment=VPN dst-port=1993,1945,1994,500,4500,1701 protocol=udp
add action=accept chain=input dst-port=1993,1945,1994,1723 protocol=tcp
add action=accept chain=input protocol=gre
add action=accept chain=input connection-state=established
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input comment=Ping disabled=yes protocol=icmp
add action=drop chain=input comment=Protection
