How can I block users with Vista to use it's IPv6 Protocol
I’m having problems on a few of my networks where the majority of users have migrated to Vista. The traffic sometimes doubles and Mikrotik is unable to identify it, if I set a Queue Per Interface the network simpply freezes.
i am using vista and haven’t noticed anything like this
Are you using Vista or are you managing a Wireless Network with many Vista Clients?
so as i understood, clients migrated to vista and vista is downloading 2 times more than any previous windows versions?
That’s exactly right, this is not a constant phenomenon, but since I started watching it happening (2 to 4 times a day), the symptom is a high bandwidth usage at a moment where the network freezes entirelly. It’s almost like if someone is sending a huge amount of data at once.
Like I said the only difference on this section, is the migration from XP to Vista, which started about a month ago and matches exactly when the problem started. We see peaks of traffic that does not match any of mangle rules in place.
:frowning:
add log rule, then identify what kind of traffic it is. Probably some kind of DDOS attack?
i havent looked at vista yet, but I believe they are using ipv6 tunneling. I imagine you could completely block communication to their teredo.microsoft.com servers so they can’t figure out what to do ?
To selectively disable Pv6 components and configure behaviors for IPv6 in Windows Vista, create and configure the following registry value (DWORD type):
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\tcpip6\Parameters\DisabledComponents
DisabledComponents is set to 0 by default. Set it to 0xFF to disable all IPv6 on the machine.
Sam
