Hello!
I want to block all trafic generated by uTorrent sw., donload &upload.
Any time that uTorrent connect, use a different port and is so dificult to block this peer-to-peer Software.
Please, someone can help me …?
Hello!
Simple rule :
/ip firewall filter add chain=forward p2p=bit-torrent action=drop
this will drop all bit-torrent connections.
What about Limewire and Bearshare???
Thanks a lot.
This was reply on another topic
Max
Now what about queuing the traffic? is:
[admin@Core Router] /queue simple> print
0 name="P2P" dst-address=0.0.0.0/0 interface=ether4 parent=none
direction=both priority=8 queue=wireless-default/wireless-default
limit-at=1000000/64000 max-limit=1000000/64000
total-queue=default-small time=0s-1d,sun,mon,tue,wed,thu,fri,sat
p2p=all-p2p
all that I need? Or do I need to enter any other commands?
Maybe I’m something missing but it seems, that
don’t block all torrent connections.
I’m using MikroTik RouterOS 4.12
The matcher is outdated.
Search the forums for more recent threads.
I tried this rule also but it not working properly.
My question: Is bit torrent traffic same as utorrent traffic?
thanks
uTorrent is a client for the bittorrent protocol.
The short story is that you can’t block p2p protocols by trying to detect them (blacklist). The best you can do is classify all traffic you want to permit (whitelist) and then block everything else.
How can i do it???.. for example… for open only web browsing (http and https)…(i know i need to open dhcp, dns, and some others… but simplify for the example… only port 80 and 443)…
