I need to configure a port of my local router to get IP from a remote router over Wireguard.
But my configuration is not working.
My original post about that problem: http://forum.mikrotik.com/t/dhcp-issues-on-port-4-despite-normal-eoip-operation/183125/1
I do not believe DHCP in general works over wireguard but there may be ways…
Check out VXLANs and EOIP as two possibilities ( running over wireguard or L2TP to keep the traffic secure ).
Thank you Anav, I found my mistake! I forgot to add the local port into the bridge.
