How can i create Network on TelePhone Line Like DSL
How can i create Network on TelePhone Line Like DSL???
what will be the senario ???
i m waiting for your good replies !!!
If you are looking to build a DSL network over actual telephone lines, then you will need a DSLAM. If you just want to build a point to point network over a copper pair (called “dry loop”) from the telco, then something like this:
http://www.dlink.com/products/?pid=562
You can get VDSL bridges. Basically they are ethernet a phone pair.
If you want to do something like the phone company’s do, you will need a DSLAM as posted above.
