How can i delete one Connection Mark name?
Hello friends:
I am using 6.41 version.
I have a little dubt:
It is not important, but i am very perfectionist and i would like solve it.
How can i delete one NOT Used Conenction Mark name?
Using WinBox and listing Connection Mark names ((I do not know if it’s the right way to call it) is listed one NOT being used actually.
Can it be deleted?
Attached screenshot.
Connection mark NAVEGACION is not being used now.
A lot of thank’s
If it’s refereed in config, even if not actually used, it will be listed, as convenience.
It is NOT refeered in config in any place.
How could i be sure about it?
I have checked all places and it is not used in any place.
If by “checked all places” you mean going through all places in WinBox, then run /export and try your luck there.
Tried /export with no luck :frowning:
It is not listed in the export.
Thank’s for your contribution.
If it’s no longer in config, then just “cached” by MT, reboot should clear it.
Rebooted and not solved :frowning:
Just to be sure, I meant saving full config export in file and doing fulltext search in there. If that’s what you did and nothing came up, then it’s officially a mystery.
Solved deleting configuration and beginning with new one.
Enviado desde mi SM-G930F mediante Tapatalk
