I’d like to disable a script but not remove it. How can I achieve this?
go to system and then scripts and first of all remove all that scripts jobs from the jobs and then try to remove the script.
Won’t that just delete the script?
I’d like to leave the script up there but simply disable it from running for a bit.
If this is not possible I assume I can download the script and save it for later. I was just hoping there was functionality to simply disable it rather than delete it.
/system scheduler
so simple.
