Hello community, good afternoon, I would like you to help me with a question. At my work they install in the following way: GPON - MIKROTIK
The problem is the following when they make the connection from the gpon to the mikrotik on port 1 of the mikrotik. If I can see it through a neighbor but it does not allow me to enter, I would understand that it is because of the restrictions it has, which is why they make the connection in the mikrotik eth2.
Is there a way to enter the Mikrotik while connected to ETH1?
