How can I export dynamic address list entries?
Some of my address list entries are dynamic.
This does not export them as it only exports the non-dynamic entries:
/ip firewall address-list export
–jeroen
Bump. Anyone?
–jeroen
it it not possible export dynamic item.
but you can do with print command and saved result in the file.
for example i want to print dynamic and static ip address list also i want store result of print command in file.
/ip address print detail file=ipaddress
Or something like this:
:local text
foreach k,v in [/ip address find dynamic=yes] do={
 :set text "$text\$[/ip address get $v address]"
/execute script=":put \"$text\"" file=dynaddresses.txt
PS: but in such case file can’t be longer 4096 bytes - it is limit for strings in RouterOS. If longer then can be written in few files for example.
One more variation for previous one:
/execute script="foreach k,v in [/ip address find dynamic=yes] do={:put [/ip address get \$v address];}" file=dynaddresses.txt
Possibly can export longer 4096 bytes due to not uses string buffer but not sure - need to be checked
I encapsulated everything in a script and it works! Thank you very much.
Below is what I did.
First I saved this in the /scripts directory:
/system script environment remove [ find where name="printExportFirewallAddressListDynamic" ];
:global printExportFirewallAddressListDynamic do={
  ## prints export entries of dynamic ``/ip firewall address-list` for a list named $value
  :local whereList "$value";
#  :foreach key,value in [/ip firewall address-list find where list=$whereList and dynamic=yes and timeout>13d23h58m] do={
  :foreach key,value in [/ip firewall address-list find where list=$whereList and dynamic=yes] do={
    :local list [/ip firewall address-list get $value list];
    :local address [/ip firewall address-list get $value address];
    :local timeout [/ip firewall address-list get $value timeout];
    :local comment [/ip firewall address-list get $value comment];
    :put "/ip firewall address-list add list=$list dynamic=yes address=$address timeout=$timeout comment=\"$comment\";";
## Examples:
## /import scripts/Procedure.printExportFirewallAddressListDynamic.rsc
## > $printExportFirewallAddressListDynamic value="login_failure_blacklist"
## > $printExportFirewallAddressListDynamic value="port_scanners_blacklist"
## note the many escapes needed here and that the export will be called "login_failure_blacklist.rsc.txt":
## :execute script="\$printExportFirewallAddressListDynamic value=\"login_failure_blacklist\"" file=login_failure_blacklist.rsc
## :execute script="\$printExportFirewallAddressListDynamic value=\"port_scanners_blacklist\"" file=port_scanners_blacklist.rsc
Then I tested the /import to verify the foutput.
Finally I executed bout :execute statements that generated multi-megabyte output files.
This works, which is way cool.
Note the scripts can take a very long time to execute even on a fast device like a CCR1009 (it took ~ 10 minutes to generate two files > 2 megabyte).
–jeroen
/ip firewall address-list print detail file=ipaddress
ip firewall address-list print file=filename detail where list=listname
Importing the list may have an error due to an existing entry; therefore, use a safe import script-
(note: replace YOURFILENAME with port_scanners_blacklist.rsc, login_failure_blacklist.rsc, etc.)
:local filename "YOURFILENAME"
:local filecontent [/file get $filename contents]
:local linecount 0
:local successcount 0
:local errorcount 0
# Split file content by newlines and process each line
:foreach line in=[:toarray $filecontent] do={
    :set linecount ($linecount + 1)
    # Skip empty lines
    :if ([:len [:tostr $line]] > 0) do={
        :put ("Processing line " . $linecount . ": " . $line)
        # Try to execute the line as an import command
        :do {
            # Execute the line as a script command
            [:parse $line]
            :set successcount ($successcount + 1)
            :put ("SUCCESS: Line " . $linecount . " imported successfully")
        } on-error={
            :set errorcount ($errorcount + 1)
            :put ("ERROR: Line " . $linecount . " failed to import - continuing...")
:put ("Import completed!")
:put ("Total lines processed: " . $linecount)
:put ("Successful imports: " . $successcount)
:put ("Failed imports: " . $errorcount)
No file size limit, no error on import if already present.
All lists:
:execute file=exp_dyn_list.txt script="\r\
    \n/ip firewall address-list\r\
    \n:local beginstr \":execute \\\"/ip firewall address-list add\"\r\
    \n:local endstr   \"\\\"\"\r\
    \n:local iadd 0.0.0.0\r\
    \n:local ilst \"\"\r\
    \n:local tout \"7d\"\r\
    \n:put \"/ip firewall address-list\"\r\
    \n:foreach item in=[find where dynamic=yes] do={\r\
    \n    :set iadd [get \$item address]\r\
    \n    :set ilst [get \$item list]\r\
    \n    :put \"\$beginstr address=\$iadd list=\$ilst timeout=\$tout \$endstr\"\r\
    \n}\r\
    \n"
Just add the wanted list:
    \n:foreach item in=[find where dynamic=yes and list=\"MY_LIST\"] do={\r\
    \n}\r\
    \n"
@drodecker
Can you explain the sense of your post in the resurrected 9 years old topic?
The topic is "how to EXPORT..." and you post "how to IMPORT"?
