I want to drop some incoming UDP packet by matching binary content
e.g. \x00\x00
How can I do that?
I only found two ways to filter the packet
- filter content rule.
this only match simple fixed data (\x00 is not working) - L7 protocol
cannot match \x00 and case insensitive
If I can create an dedicated firewall facility, where should I insert into?
Lan <===> 3 ADSL by PPPoE
if I put the firewall under lan port, the router will not get protected.
if I put the firewall under wan port, the firewall cannot understand pppoe.
