Hi there. I faced a problem recently. SVI of my switch doesn’t get IP-address via DHCP server on my Mikrotik 951Ui-2nD (6.42.1). Although it gets IP-address via ISC-DHCP server. I’ve watched the log but can’t find the reason of NAK. How can I do that?
P.S. Attached log from mikrotik. 2200.txt (3.59 KB)
No, you may have done the export but you have not posted it on the forum for us to see what you did!
However, it is not very likely that this will solve the problem. It is wellknown that there are some cases where a client (which does not behave well) does not get an IP address from the MikroTik DHCP server while it has no problem getting one from other servers.
It might help when you post the wireshark decode (all fields unfolded) of a single DHCP exchange here.
You can use tshark (the commandline version) with the -V flag to get a comprehensive decode of the entire packet (one packet outputting like 100 lines).
So post only the 3-4 packets of a single exchange.
