Then people can’t check sites like http://www.lagado.com/proxy-test to see what I am running…
In school environments you tend not to want to show so much…
Then you can have a check box to activate it under the web-proxy. That way people can choose to or not to use it.
Beside this it’s an excellent proxy! Slim and fast!
Standards and protocols are just old information on pieces of paper on some dusty shelves. Just BREAK the standard to satisfy the customers, after that - publish it as your own RFC, your own standard. This is how IT ACTUALLY ALREADY WORKS.
we have no plans to make such advanced proxy features, RouterOS is still primarily a router. you can use parent-proxy feature and do your youtube caching there
Okay My primary concern was more security related. Not to give off to much info.
I agree it’s not intended as a UTM box My thoughts was perhaps something to test in the v4 beta… if it was not to much afford to make it.
I personally use it as a transparent proxy without caching… Just for the HTTP security feature.
That is also true, There are definitely more things that the proxy provide beside security.
It’s just in my case more interesting to do security when we don’t have a capacity issue. That’s all…
I think if it is possible to have a separate package that implements more advanced proxy features would have been great.
However I can understand Normis/MikroTik’s view on the matter, It’s still foremost a router… Beside how many “routers” have proxy and all the special functions that RouterOS have? I mean take a look at Cisco
But as I wrote before if they can make these features easy then it would be great, That I think we all can agree on.
If not in this version then perhaps in the v4.0 when it is released.
