How can i import my 2500 pppoe customer in user-manager?
How can i import my 2500 customer in user-manager?
I think you cant import, you have to configure Manually
You can! Just make an “import” file that you will “import” from the console. You have to figure out what is the command to add a user, then just use “find and replace” in Excel (for example) to add this command before credentials of each user.
THX
I will test it!!
