How can I import my hot spot users list
Hi
I made a backup of my hotspot users
IP>hotspot>user>export file=usersbackup
and I savedthe userbackup file using binary transfer into my laptop, now if I want to rest my RouterOS 500, how can I import thatbackup list again.
I dont want to re enter all the users again..
Thnaks in advanced
Regards
open that file in notepad or some other editor, copy the commands starting at “/ip hotspot user”, log in to the MikroTik, and paste them in.
Thanks bokad
:slight_smile:
If you have profiles other than the default profile you should import those first, otherwise the user file will not import into the new router if the old PC had users with profiles that aren’t defined on the new PC.
yeah.. that’s right, I should import the profiles also
Thanks to bring my attenation for that
:slight_smile:
Regrds
sal
