Hi, i would like to make use of the Routerboard to monitor my UPS which it come with the file for linux use [xxx.tar.gz].
is there any where i can install it.
appreciate it.
appreciate it.
If you have an APC ups then you can monitor it directly from ROS, excluding ROS 5.20(it doesn’t work there). If you have another one, you should take a look in the KVM manuals. I personally have 2 UPSs from APC and both of them are monitored through ROS.
