how can i limit users according to amount of download ?
i have 15 users some of them download alot and i want to limit them after they reach 6 gig per day
my ip for users 10.0.0.1 can anyone please help and explain steps because i am new at this
write different simple queries and simple script that switch them for, after exceeding their limit, throttling heavily them further.
it would be easier if queries support address lists as arguments for input/output. so you can use it for consumers put in them(with sane/relevant time-out, generally)rather than market connections.
or you can simply implement(because 80% over-consumption is p2p/bittorent)torrent detection and throttling or even completely shut it off. i forgot relevant topic, but there was quite handy thread about some time ago(you can use “search” above to find it).
maybe because it is so important that we need to limit speed to save bandwidth or it is a problem .mikrotik should solve this in sort of way by now shouldn’t they ?
This is a common task, well explained in the manual. It would be great if you could read the manual first, experiment yourself, and if you don’t succeed - then ask for Forum user help, with specific configuration that you already made.
