I need help on how to move the usermanager on my router (ccr1009-8g-1s-1s+) to SD card and also point all logs to the SD card.
The SD card is 16GB and I can see it on systems-disk
Hi funky712,
I have the same problem, I need make the usermanager active on SD card, I have RB1100AH X2 with ROS v6.28.
Thank you.
