How can I see connections in LAN
Hello.
I have one device connected to ether-2.
And to the ether-3 I have connected the second device.
How can I see connections between them, like in Torch tool ? I would like to see which ports they are using, how much packets they sends.
Peter.
Go to:
IP → Firewall → Connections tab!
There you see everything going on… IF these are IP connections (like LAN to WAN).
If they are part of the same bridge/L2 network you will need to use torch!
In Torch I can see only LAN->WAN connections. (on etherX, bridge interfaces)
I have checked at my RB951 and RB941.
But on 911G with Wlan I can see all LAN traffic at ether1, wlan1 or bridge interface.
For Torch to see the traffic, you will need to disable “Hardware Offload” of the interfaces bridged in Menu–>Bridge–>Ports
Note: This will have a negative performance impact for traffic between interfaces in the bridge
