How Can I Share Tranfer Limit To More Users Like Group
I have 4 subscribers who I want to share a 4 GB usage so that each person can use as much as he wants until it runs out. I Need Share Transfer Limit
I have not a clue as to what device we are supposed to be talking about. But I can say this.
From the semantics of the problem, just run it until the 4GB runs out. If there is a cost penalty to continue beyond 4GB, cap total usage at 4GB. The fact that there are 4 users is irrelevant under these rules, they act together as a single effective user.
Just let them use the same login.
The answers given by Artificial Intelligence seem really Deficence to me...
Basically,
you need to configure the hotspot feature, combined with the user manager,
where the same login can be used on up to 4 different MACs simultaneously,
so that once the allocated traffic is used up, no one else can use it.
Or simply create 4 users, 1GB ones, and you're done...
1GB x 4 logins is not the same as 1x4GB for one login.
I know perfectly well, once one login is depleted, he uses another...
So he knows exactly when he's already used a GigaByte, and so on...
If you are referring to me, I wrote that unaided. If you had used AI, you might have used the right word, if we are going to be pointlessly picky.
You wont be able to do this β€˜out of the box,’ but it is certainly possible with some custom AAA integrations.
Why not use a device which is designed for such things? Like a NAS from QNAP or Synology.
ROS is router, not a storage system. It’s like using a screwdriver to drill a hole - it will maybe work but it will cost a lot time and is difficult - simply the wrong tool.
How can I do this tell me please
I have 4 users in hotspot they need login by make and need use like 50 Gb but not need give everyone 10,10,10 and 10 gb no they need share 50 everyone
For a hot spot, you can create a single user. From WebFig set Shared Users = 4 in [IP β†’ Hotspot β†’ User Profiles β†’ ?] and set the limit in [IP β†’ Hotspot β†’ Users β†’ ?]. This will allow all 4 users to log on simultaneously and share one limit.
Already written,
OT doesn't read what it doesn't like,
and it reads what's useless, as usual when you don't give people exactly what they expect.
@mrsalahaldin 4 different users, one unique pool:
It can't be done, you can only get around it with OTHER solutions.
Like to create 4 different users and, using scripting,
continuously sum the traffic used by each one and, when it exceeds the limit, deactivate all 4.
