How can I test stability of my WAN connection?
Hi, I’ve an android box showing streaming on TV, instead of other 2 locations where the channel works smoothly without interruptions here I have them and quite often. Internet works and I can’t understand if it’s loosing packet6or brake my TCP sockets connections, there is a way to test how often a TCP is interrupted or packed lost? Better between 2 mikrotiks, if not possible between 2 windows PC. I don’t need an aggressive test, it should keep a connection of for e610Kbyte/second and log me all problems. Thank you for suggestions!
Any suggestion? Thank you for kind help!
https://www.packetlosstest.com/
