I am trying some usb umts/gsm/lte keys in my mikrotik.
This command shows them:
/system resource usb print
But then I cannot find any port with this:
/port print
What does it mean? It is not supported? Can I change some settings?
Thanks in advance for any help.
Mario
Ok I assume they are not working or usb-modeswitch is not called?
Anyway I read that if I send info to mikrotik they will support it, but when? In next update of routeros?
I have several models of keys to add.
